Parachute Adams
- Aug 17, 2013
- 32
I have ordered a Faria water pressure gauge (30psi) and a Faria cylinder head temperature gauge (60-220F) for my Evinrude E70TLCRD (70hp, 1984).
The install for both are pretty self explanatory.
Water Pressure Gauge:
The instructions say: "On your engine, locate and remove the plug that is screwed into the water-cooling jacket. Replace the plug with the proper size male tube fitting (one 1/8NPTF fitting supplied). Push one end of the supplied tubing securely
onto that fitting."
Now, is this plug where the Tell-Tale is already plumbed into or is there another plug? I want to install a Tee, where the Tell-Tale plumbs into motor, and run the pressure gauge line and the tell-tale. Or, should I locate this plug on the jacket? (Assuming it's not being used for the tell-tale.)
Cylinder Head Temp:
Pretty easy to install, just remove an upper cylinder bolt and attach sender and reattach bolt.
thanks for the clarification
onto that fitting."
Cylinder Head Temp:
