I have a 2000 Johnson 50HP model J50PLSSM it dies at idle, if you use the high idle start it will start and stay running @ 2000 RPMs occasionally running away to 5000+ RPMS, but at low idle it dies every time.
Carbs cleaned and rebuilt( intermediate orifice was found in the bottom cowling prompting the rebuild)
New VRO PUMP installed (was pumping very aerated fuel)
New pulse limiter
all lines have been inspected and replaced as needed
Sync and Link performed
Compression is 120 on both cyls
Good spark jumps 7/16" gap and is bright blue
new plug wires
Engine de-carbed
where to go from here?
New pulse limiter
new plug wires
Engine de-carbed
