I have a 1986 120 HP Johnson that intermittently stops firing on all cylinders. The engine will keep running while this happens, resulting in the engine jerking back and forth as all 4 cylinders fire and then stop firing. It also stalls a lot when this is not happening. I believe that if it was a power pack, then this would only happen on one bank, and not both? I'm sort of unsure how to proceed from here. From what I've read it seems likely that this is the stator or timer base, but I wanted to get from input. Any help or suggestions would be greatly appreciated.
