SnickerBocker
- Aug 14, 2013
- 2
To begin, I have no experience with anything that has to do with boating, so forgive me if I don't understand boating lingo. I have experience and knowledge about what makes engines run, how they work, and stuff like that, so I'm not completely hopeless. And finally I'm not afraid to ask questions.
The engine in question: 1972 Evinrude Triumph, 65 Horsepower 3cyl. Model: 65273S Selectric Hydro-Electric Shift
The story: My grandfather bought a boat, I don't know the year but it's a Larson, anyway he got the boat, and it had no engine, so he found the 72' Triumph and I'm not sure who installed it, I assume he did as he is knowledgeable about boats. He has had it for a number of years but as time passed he used it less and less until about 3 - 5 years ago it quit shifting and would only go forwards. So just this year, a month ago really, he was looking to get rid of the boat, and I was looking to buy one, so obviously a deal was made.
What I Have Learned: The basic engine info, such as the power, year, and that it is a Hydro-Electric Shift, and how that works. Apparently there are 2 Solenoids, one with a blue wire and one with a green, when just one is activated it is in neutral, when both are activated it will go to reverse, and I understand the engine needs to be turning for the oil pressure to move the dogs.
Where you friendly people come in: I have looked up the issue on google alot, and there has been alot of information about it, people saying change the bottom end fluid, maybe it was contaminated or the wrong type, and check the solenoids with amp ratings and ohm ratings and the like. So I have a multimeter and I know how to use it, but the things I have read are having people take the knife connector for the solenoids off at the power head, which I cannot find. If I have to disassemble the unit, so be it, I have tools, and I have space, I just don't know what to do and how to do it. I have a shop manual for Evinrude Engines that I believe covers my model.
To sum it up: I have a 1972 Evinrude, 65hp Hydro-Electric Transmission (if that's what they're called in boats) that stays in forward (which I understand to be a safety mechanism).
Any help would be appreciated, and if I need to clear things up or elaborate more I definitely will, once again I have no boating experience, so I don't know what I need to say or what I've left out that could be helpful. Once again thank you in advance.
Things I have done:
Changed Bottom End Gear Oil, C - Rated
Tried to figure out where wires go
and that's it.
Things I have done:
and that's it.
