Tom Maslar
- Jul 29, 2011
- 137
:facepalm:I am almost done with mechanical restoration of my 1960 Evinrude fastwin motor. Well, IJust have to set up carb and was reading in the manual that the high speed screw, which is attached to a linkage, should be disconnected from the linkage, then lightly seated, then backed out 3/4 turn, and then you are supposed to put the mixture adjustment knob back on the adjusment shaft, making sure the knob is pointed to the 3 position, and then, finally, re-connect the linkage between the adjustment knob and the actual high speed needle. Here is were I am dumb founded: The mixture screws adjustment knob, has a limited Range of motion. For the adjusment knob the faceplate is marked 1 to 5. With the prescribed aformentioned set-up of the high speed screwand adjustment knob, my range of linkage motion is from 3 to 5. ---from 3 to 1--which also says lean under it--is not possible because the linkage ends its travel. Tried nine ways to sunday to get linkage to allow knog to go from 3 to 1 marks on faceplate when turning it --cant make heads or tails of this:mad-new:
