I am not sure if I have a problem here.
Engine running on muffs.
If I open up the throttles at the OMC controls it revs up fine.
On the other hand, If I hit throttle linkage at the dual carb system the engine bogs down, coughs and dies. I could swear it didn't do this before. I believe you bypass the timing mechanism if you open the throttle at the carbs....but with no load I don't see why it shouldn't rev up.
Any thoughts??
Any thoughts??
