TOP1PERFORMER
- Jul 13, 2013
- 21
Hey guys any thoughts?
I have a low hours and very clean 1987 88 SPL. Engine runs great looks great. Water coming out from the top front midsection near the top pivot. Removed the cowl but can't see up there close enough where it's running from.
Last week I pulled everything apart to try to find the leak. Did not see any corrosion. New water pump, seals, o-rings, gaskets, super cleaned all surfaces at powerhead and exhaust adapter. The leak is still there. Called Evinrude direct and they thought that maybe the mating surfaces between the powerhead and adapter may be warped. Suggested trying another new gasket with Permatex #2. I did use a very light coat of silicone sealant on both sides of the Powerhead/Adapter gasket which may not be preferred. Exiting water looks very clean and not contaminated with oily exhaust. If no ideas then I might need to install the powerhead without the lower engine cover/shroud for an open view and then disassemble and reinstall again. Ouch..
