G'Day all
Okay I have what I am told a 92ish 55 HP commercial outboard that was sourced from the Australian Army, no model numbers were left on it so its all from photo identification.
I pulled the lower unit off to replace the water pump and that looks to be from a 97 or newer lower leg according to the part numbers on the pump cover.
Now the issue I have is that due to the kit i bought for it (5000308) coming with a 6 blade impeller (the old was a 3 blade) they say I need to replace the thermostat housing and spring as it will run to cool at idle.
This is where I run into my issue and that is the thermostat housing and spring they specify pt nos 343977 and 343141 are nothing like my set up and I cant seem for the life of me how it is supposed to fit?
I will attach a photo of my outboard plus the water pump housing - which is part number 438545 next to the kit cover that a 92 should have.
What alternatives do i have for the thermostat cover and spring change over? or is it though luck its going to run cold at idle?
Any Help appreciated
Cheers
Fletch
Cheers
Fletch
