green head
- Oct 31, 2009
- 37
My outboard isn't circulating enough water I am guessing the impeller or whole water pump needs replacing. But I can't get the lower unit off. I found 4 bolts and one nut to remove. I think it is hung up on the shift rod because I can't find the disconnect. I took off the plastic intake screens and found a odd nut like thing that only spins with no signs of being threaded. Any info on how to disconnect the shift rod and the best way to reconnect it would be very helpful. Thanks.
pic with bolts and nut removed. Hanging on the shift rod. Don't think there is a screw to disconnect in the gap because there isn't enough room.
pic of nut like thing behind plastic intake screens that only spins.
