Jim Hawkins
- Mar 11, 2013
- 499
A little help from someone familiar with these remote control cables. My Box and cables are from a 1968 boat and I want to connect them to a 1986 motor. I have already attached the throttle cable and will be able to attach the shift cable no problem but I have one issue I'm wondering about.
The above photo shows a funny little spring/pin thing on the end of the cable connector. I can't figure out how to get it off without wrecking it so I can attach the connector to the lug on the shift lever as shown below. I don't want to wreck it if I don't have to cause sure enough I'll probably want it someday.
Ok, I know your going to say, " just drive out that little pin that goes thru it crossways" But I've tried hammering it out and all I'm doing is blunting the end of the pin.
