peterskeeter
- Aug 24, 2008
- 86
Hello all, launched the boat today just to do some trailer work. Installed some LED lights and all was well until I tried to crank the ole boat up after. After a few dragging turns of the starter, I figured either the battery was dead or the battery terminal was acting up. So I played with the battery terminals, the negative side was hot. Still no luck getting her started. Brought it back to the house, cleaned the battery terminals and installed a new one on the positive side. Cranked her over and the starter spun like normal. Then, I saw a little spark off the terminal and that was it. No more trim, no buzz from the overheat sensor, no turn of the starter, no electric choke.... NOTHING! I checked the 20 amp Buss Fuse and even swapped it, still nothing.
Would a starter solenoid going out cause me to have NOTHING? I have battery voltage at the starter lug and solenoid lugs. I'm not too good at chasing electrical problems. Any ideas would be greatly appreciated! I don't want to throw unnecessary parts at the problem. THANKS
