Boss Hawg
- Apr 9, 2009
- 1,433
Had fuel delivery problems but fixed all that & bulb is now staying firm---Starts fines, idles fine & runs fine up to around 10mph (will do 30 when running right on my pontoon) but then bogs down? I can throttle down before it dies & it'll idle fine & go again at slow speed-if it dies it'll start right back up.
Compression is good & equal on all 4 cyl-
Cleaned carbs
New fuel pump
New tank
New bulb & fuel line
Coil failing under load maybe??
Don't know how to check that & can't think of anything else to do :blue:
Cleaned carbs
New fuel pump
New tank
