CaneCutter79
- May 24, 2009
- 454
I got my motor rebuilt in Feb. of this year. It's been plauged with the same basic issue since I got it back. It could have been starting before the rebuild and to be honest, I think it was.
Motor starts fine when cold.
Motor starts fine when warm but....you MUST use fast idle to get it started.
When you use fast idle cold, the motor idles up like it supposed to. When warm, no go. There is little change in rpm and it simply won't run correctly without fast idle. It may continue to run and idle and eventually it either chokes out (makes a gasping sound as it dies) or it eventually gets better and continues to idle.
When it's bogged like this, if you engage it in gear and esentially "floor it", it will gasp and grumble a little and then take off as it should. This evening, it would bog and not get on plane until something kicked in and then it shot out of the hole like normal and took off.
Weird thing is, it runs really well at WOT. It's a 34yr old rebuilt motor on a heavy little tri-hull and I was clipping 38-40mph in choppy water this afternoon so it's running as good as it ever has.
COmpression is good too. 110psi on re-honed cylinders and 120 on resleved cylinder.
ALL of this problem is once it gets warm or when it's trying to idle. When I start the motor and back the boat off the trailer cold, it does this sometimes. It just doesn't like to run at low RPM. Anything below 800rpm and it develops this issue.
It's also getting plenty of gas because when you bump the choke on the key switch, it only makes it worse. So it's not fuel delivery. It's fuel to air mix or spark. Maybe too much fuel at low RPM? My mechanic seems to think I should change to a smaller orfice on the low RPM jet. All of the part numbers i find are only for one part with no variations for altitude. My home lake is 1,121 today above seal level and 1,118 at normal pool.
After many months of this....motor fighting me when trying to load (bogs out and dies trying to load) I'M SICK OF IT! I'm ready to get this fixed.
Where should I look? Is there a couple of electrical tests or something I can do to help find the issue?
Oh, and I've cleaned the carb. It was rebuilt as well. I've taken both carbs apart and they are clean and functioning properly.
