Hi All,
I have a '69 Evinrude 85 HP and im having problems getting it started. It will try to fire but just wont start and run completly. I have fresh fuel, new spark plugs, new ignition coil. In the past the engine would always start and run with a little TLC, but now I just can get it to go. Any ideas? I heard something about a "hot start" feature. Im not sure if this engine has this. I know there is a linkage from the throttle that adjusts the timing. Anyone have more info on this?
Thanks for you helP!!!!
