sea you on the bottom
- Jun 14, 2011
- 3
I had to replace the ignition in my 1975 remote box and found that the throttle spring needed replaced also...got the spring in but now I can't get the outer housing back in. It came apart easy enough but I'm now stuck getting it back together. Is there a trick to do this or do I have to disassemble the entire controller to get it back in ?
