Hello all
Does it matter how the primer bulb is mounted i.e vertically vs horizontally?? I know the fuel flow needs to follow the arrow, but since I don't know for sure how the check valve/ball works I wondered if it mattered whether the bulb was vertical or horizontal. I have always been in the habit of 'pointing the arrow' up when I pump the bulb, don't know why.
Curious if there is a preferred orientation to help keep the system primed or not.
Thanks
Wxman
Thanks
Wxman
