I recently bought a boat with a 93' 70HP Outboard (With Carburetor). Since I got it, it has been running rough. Stalling when put in gear, when idling, and wont go past 3000 RPM. I have had it checked by a mechanic several times and they found some electrical issues that was causing start problems but this issue with stalling, etc persists. I decided to dig in to the fuel system and found that the fuel pump has the electrical line cut. I have a primer ball which checks out ok but when I checked the fuel pump, no fuel would go thru when I cranked. I am thinking I need a new fuel pump and per the Johnson parts list it is supposed to be electrical. Main questions are, Is there some reason someone would cut the electrical line? Should i replace with an electric fuel pump per the OEM specs? With no power, would an electric pump work like a mechanical? I am about ready to dump this engine if I cant figure this out. Any thoughts/advise would be appreciated. Thanks!! OEM Part Number for the Fuel Pump is: 0435560 FUEL PUMP ASSY. $484. Would hate to go by a OEM replacement for $400+ if this isn't likely the problem.
