I can't get the OMC sealer locally for the heads that use O-rings on my '96 175 Johnson motor. Is there any difference in RTV silicon and Permatex #3? I've heard not to use silicon on heads but this is to seal the water passages the best I can tell. Ant tips on applying it because I've never had much luck with silicon on metal to metal cases?
