Having problems shutting off my 150 evinrude 1995. Turn switch off, stays running. It shuts off fine when it's cold, once it warms up the engine won't turn off the other the switch it the safety lanyard. I pulled the ground and black and yellow wires from the switch and connected them together and it still wouldn't shut down. I pulled the hood and traced the black and yellow wires, and disconnected and reconnected the plugs, still wouldn't shut down. Finally I pulled three spark plug wires off to shut it down. Where does the ground wire that grounds the power pack to shut it down connect to the block. My buddy thinks it's a bad power pack, but it starts and runs fine, just won't shut down when it's hot. Any help greatly appreciated.Thanks
