Re: 65 hp 1972 evinrude battery charge
Yes it should charge the battery.
I would check
for an AC supply to the rectifier (between the yellow wires)
for DC between the red wire and ground
If no DC output from the rectifier you can check it following the instructions in the engine faqs board (but if you use a digital multimeter use it on the diode test range not an ohms range) or assume its blown and replace it.
BUT
If you have a decent battery and you have properly charged it it should start the motor many times even if the motor is not recharging it.[/QUOTE
I`m missing something here but on my 65hp all I have is 2 wires coming from motor to battery, and that's the large red/black wires. what is charging the battery? the red wire hooked to the starter?
