Re: Evinrude 40 cv big twin 1965
???? Cable???? There isn't that much wiring to a manual start motor. You have a stop button, with one wire going to the magneto, the other one going to the center post on the vacuum cut-out switch. Another wire from that center post also goes to the magneto. A white wire connects the outer corner of the vacuum cut-out switch to the switch below the magneto pate. I think that's about it, did I miss anything?
