Alberta angler
- Aug 7, 2013
- 4
Hi I just bought a boat with a 1992 Johnson 60 hp 3 cyl and the middle piston is burnt and likely wrecked the block , but I would like to know if I can put the entire block and carbs etc from a 1983 Johnson 70 hp 3 cyl in to my 1992 frame and leg. I'm really mechanically inclined I am just unsure if the older 70 will fit in the newer 60 frame before I go out and buy the parts motor. Thanks any input will be sweet
