Re: OEM spec plugs for a 1995 Johnson 175 fast strike?
So, the above recommendations were erroneous...
Your manual is correct at that time but due to flaws in ignition system and todays fuel they where revised to us the QL78YC plugs...
So, $24 dollars worth of plugs go in the trash or for an emergency I guess... Geez...
Put them in as they are correct..below is paste from revised OMC/BRP spark chart
150, 175 (60? V6) 1991 & newer QL78YC (see note 3) .030
150 Commercial (60? V6) 1993 - 2001 QL78YC (see note 3) .030
NOTES:
1. All spark plugs are Champion brand unless otherwise specified.
2. When more than one plug number appears, the first plug listed is the prefered spark plug.
* This chart was assembled with the latest available Parts Catalogs, Service Manuals and Service Bulletins as of the
revision date.
3. On ALL VRO/OMS equipped motors the "QL" supressor plug is recommended.
Revised: 3/5/2009
