DPManley
- Aug 6, 2013
- 26
Hi All - my first post.
I have read a BUNCH of posts and I am still stuck.
I have a 1978 85HP Evinrude. The impeller has not been changed in years. Overall, running well. So I followed the manual to drop the lower unit. It says to shift into reverse and remove the shift lever bolt - done.
All bolts are out - The lower unit drops about 1.5 inches and is stuck.
Moving the lower unit moves the shift lever located under the carbs. I tried holding it in reverse and wiggling the unit - no luck.
Notes: I made sure the gears are in reverse - the prop is engaged. When I dropped it as far as possible, I was able to turn the prop and feel the splines just rubbing the engine so the splines are not seized.
I tried one person holding the shift lever while I moved the unit.
The shift lever is a right angle pin that seems to be directly connected to the shift shaft. I tried to slide the pin but it does not move much side to side.
How do I get that shift pin disconnected?
