i have a 1993 evinrude 120 outboard, just replace the water pump, but seems the water pump not working good, when i start the moto in idling, i can see Small water column flow from the moto right side end, but when i run forward in three or four mins, the water column can't be seen and seems the water pump not working any more, then i stop the moto , i use water Reverse Flush many times and restart the moto , the pump work again, but can only work in idling mode, once forward or backward, the water pump stop,and the water column can't be seen again, anyone can tell me what problem is it? thanks in advance!
