Sippen
- Jul 23, 2012
- 65
Hello,
Looking for some advise on this motor. Thank you for any help in advance.
Motor is labeled a Gale which is in the Johnny/Rudy family. (Model 40DE14B)
(earlier thread was focused on fuel pump, sorry for redundancy)
I had it on the water this past weekend. A little rough at low idle in gear. smooths out in high rpm and gets on plain fairly good (14' '58 tin Cadillac), then after 30 seconds it is bonking out starving for gas, a quick pump on the gas ball primer and it keeps going, another pump later and it keeps going... What should I check or replace next?
so far,
replaced fuel pump diaphragm (kit)
fuel line
female fuel line connector to motor
-The gas ball primer was not replaced, could this be the problem? looks in good condition
-took tank apart (older plastic). siphon looks ok. Not sure if purchasing a new tank and male fuel line connection should be done. (a little bit of rust on the male connector to gas tank)
-Should I open up the fuel pump again to inspect?
Thank you,
dave
so far,
fuel line
Thank you,
dave
