bass man89
- Aug 5, 2013
- 6
I recently took my boat out and put it into the water for the first time in about 2 years.The boat ran great a couple of years ago with two six gallon gas tanks. I recently went to a 12 gallon gas tank with the same fuel line and fittings. To continue I Stopped on the way there and got fresh gas and mixed it 40:1 with the oil. Got to the ramp and cranked it up after pulling the motor cover off and spraying starter fluid in it. Revved the motor up for a couple of Minutes to get it warm put the cover back on and off I went for about a minute. Then all of a sudden it sounded like it was starving for fuel and died in the process. I cranked it back up and it did the same thing all day. However when I was going slow it was fine. I made a phone call on the water and got told to clean the filter in the gas line which I did installed it back and the same thing happened again. I got back home and have been told it was a carburetor issue which I had to clean the carburetor before I took the boat to the water after the clean it ran great on the water hose. After I got home from the water it runs good on the water hose sAme fuel and tank with the throttle open. I've also been told its the size of my gas tanks I need to either get a better fuel line or go back to the six gallon tanks which I haven't tried in the river but on the water hose it runs great. Any ideas or recommendations?
Also tired venting the gas tank and still didn't work when I was on the water.
Also forgot to add I use to mix the oil ratio with the gas 50:1 when I went out the other day I mixed it 40:1 like I said runs great on water hose but when in the water under throttle runs about 2 minutes tops. Could the 40:1 cause this?
Checked the fire on all the spark plugs today and all 4 plugs are getting fire going to try again Thursday morning with 50:1 oil and gas on 6 gallon tank any more ideas?
