I recently bought a 1979 Evinrude OB (Model 2902A) that runs great and has great compression. As preventative maintenance, I wanted to replace the water pump. According to all the info I could find on the net, you remove the two bolts From the gear case, just in front of the prop. I did this and the prop housing will separate about an inch and then it is restricted from coming out by something higher up. I would guess in the area where the splined drive shaft attaches to the engine block assembly. None of the drawings I can find show anything to keep it from coming out.
Does anyone have an idea what is restricting the removal of the lower gear case? Do I have to go into the powerhead to disconnect something?
Thanks in advance for your help---RAHFISH
