Birdchaser305
- Aug 4, 2013
- 2
I have had a lot of problems with this motor. To begin I replaced the emm. Then it ran great for a year. Next the lower unit had to be replaced. Now the last time I took it out it shut off and I got towed in. I have the diagnostic software and I had two faults. One was the CPS loss of sync. Well the bolt holding it in place was missing. I replaced it. Second it had an over heat switch closed fault. I then changed the impeller. I no longer have any faults but the motor is missing at low RPMs. And I took it out for a test run and it died again after about 45 min. I couldn't get it started so I took the hood off and the EMM felt hot. About 20min later it started an I went back to the dock with no issues. I hooked up the diagnostic software and have NO FAULTS? I was concerned with the cooling of the EMM so I disconnected the hose to the top of the EMM and the water comes out a little or none at all. I shut the motor off and blew in and the was little or no resistance to the hose or EMM. I then performed the same with the hose on the bottom with little or no resistance. The last hose is much smaller and has a plastic disc but doesn't let any air pass. And when I blow into the fitting on the EMM it will not let air pass either. I also removed the thermostats to allow more water movement being I'm in south Florida and water temp is around 80 degrees. When I ran the diagnostic software the EMM was reading 53 degrees while the motor is at 41 degrees. My question is is the temp being 12 degrees hotter on the EMM a problem? Does it sound like the water flow causing the EMM to act abnormal? Again I getting NO lights on the tach. NO faults! But when I feel the EMM too hot to keep my hand on after 10min on the hose.
