I checked the manual switch and it is in the correct position. When I turn the key to the run position the choke goes on a little bit. When I press the toggle switch the choke fully engages but when I let go of the toggle switch the choke still stays fully engaged. Should the choke return to open position when I let go of the toggle switch?
