Help someone!
I have a 1962 Evinrude selectric shift 40 H.P motor. Last year, I replaced the electro magnets in the lower unit and had no problem until today. I have my forward gear up to about 1/2 throttle, then after 1/2 throttle, it is in neutral. Seems that I am losing my electric flow to the electro magnet at anything above 1/2 throttle. I checked all the wires out while parked in my garage. I have good juice and the prop only turns one way in forward gear and the opposite way in reverse gear.
When the speed is increased and the motor seems like I pushed the neutral switch, (forward gear switch stays engaged) if I just back down on the speed, I am back in forward gear. In goes in and out of gear with no banging at all. It is real smooth both in and out of gear. Any ideas on what can cause me to lose the electric to the magnets only at above 1/2 speed? What should I look for?? If the gear oil was low, could this cause what I have described? What if it has water in it? It is discolored SLIGHTLY. Thanks.
Another thought I had was maybe the prop is spun. I took that off and the hub in the center of it seems very tight and is not spinning when I put it in a vice, but I thought maybe with a lot of torque on it, it may be free spinning on the shaft??
