All,
I had a strange set of occurences happen with my 2005 Johnson carbed 2 stroke 90hp today and I am asking for some diagnostic help please...!
The problems first started this morning as I started the motor. I noticed a sheen of fuel / oil bubbling up from underwater, what I would assume is coming from the exhaust. I premix my oil and fuel.
I ran the boat fully loaded with people to the beach and it seemed to run fine. When I got to the beach I took off the cowling and visually inspected as much as I could / pumped the bulb, etc. Did not see any fuel leaks on the intake side.
Started the motor up again and seemed like the oil in the water had subsided. Was running smooth at idle.
I will note here that I did suck up some sand last week and I have had to remove the tell-tale restrictor a couple of times and let the motor flush, replacing the tell-tale restrictor cap and it is peeing really strongly. I replaced the water pump prior to the start of this season so it is new as well.
So on the way home I open the motor up and after about a minute on plane and at about 4k RPMs the "HOT' alarm starts sounding and the "HOT" idiot light on the smart tach comes on. I dialed it down and we were pretty much at the dock.
So, anyone have any ideas on what I might look for? At the dock, the motor sounded like it was running rough, maybe even missing a cylinder. Is it possible I have some restriction in the cooling system that is not showing through the tell-tale? T-stats clogged up or something? I'm also wondering if my two problems are independent of one another or related?
Any help or advice is greatly appreciated - I have family coming in tomorrow and the boat is a big part of the plan for the visit!
Thanks,
Dave
Thanks,
Dave
