Hi guys,
I have a 1992 55HP Commercial Johnson, I ordered a new water pump kit for it Pt no 396933. I got the part number off of the Shop2.evinrude site, but when I pulled the gear box off and took the water pump off I ran into a massive problem...the kit doesn't fit, nor is it close! Bigger housing, impeller and the holes where it slides down the shaft is smaller in the new kit - see pic.
It was an ex Australian Army motor and thats all I know, it takes the larger diameter 13 spline prop if that helps?
Which kit do I need to order? any help would be great.
Cheers
Fletch
ps any one in Australia want a cheap water pump kit? Pt No 396933?
Cheers
Fletch
