I’m trying to understand how to link and sync this motor. I have tried to do this but can’t get the scribed line on the cam and pointer to line up before the roller engages the throttle butterfly. It’s as if the throttle rod that’s connected to the throttle arm over rides the roller and cam and therefore adjusting eccentric doesn’t help .I can get the pointer and scribed line to line up correctly by adjusting the throttle rod so it’s less engaging but then I can’t get full throttle? I was lining the scribed line and pointer up using the throttle control but I’m not sure if this is correct? Should I be using the armature plate? If someone could give me a step by step procedure on how to do this it would be appreciated
Regards Kevin
Regards Kevin
