Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
1969 Evinrude push button shifter
  • 1969 Evinrude push button shifter
    Hello Gents,
    My 1969 evinrude is running great. the only problem i have is when i put it in reverse you hear it go in and feel it pull at idle but when you idle it up it sounds like it is not fully in gear. I am still learning about these engines. I have years of pratice on cars but i am learning that outboards are oranges and not apples. any info would be great.
    Re: 1969 Evinrude push button shifter
    What kind of oil do you have in the lower unit?? It should be type C or premium blend.
    • #3
      i don't know i haven't changed it yet since i got it
      • #4
        Very important to know before giving advice: What size of a 1969 Evinrude motor do you have? The 40hp works entirely different than the larger motors.
        • #5
          He did say push button shifter and they use premium blend.
          • #6
            It is a 85 hp. Where do you find the oil for the foot?
            • #7
              Any BRP dlr, maybe Wal-mart or West Marine. Just make sure it's premium blend or type C.
              • #8
                can this be causing my problem?
                • #9
                  Possibly with the wrong oil in it.
                  • #10
                    we'll went to change it today and found that there is water in the oil. It looks like the seal behind the prob is leaking because with the engine not sitting up oil started leaking out from behind the prop. Is this a seal that is hard to replace?
