1993 Johnson 140 hp
bigfish33
Just purchased a new rectifier from Johnson to install it has the same 5 coloured wires on it. The red wire is a lot longer and has a large ring on it. Does the red wire need to be shortened and a new eyelet put on it to screw down to the bus terminal or does it go some new place? The last one melted after the tach kick the bucket.
Joe Reeves
Re: 1993 Johnson 140 hp
I think you'll find that the red wire large terminal connects to the same battery solenoid terminal that the Positive battery cable attaches to.
bigfish33
Yes that worked well everything now working as it should hope to be out fishing for chinook salmon on the weekend thanks!
