just bought this boat about a month ago. its a pontoon with a 1994 88hp johnson. when purchased i changed lower unit oil, changed spark plugs and it ran fine. it has always run great with no problems until the other day. started it up to unload from trailer, loaded up the family and headed out. I only ran it for about 10 min before shutting it off to eat. About 15 min later when i went to start it back up it wouldn't start. I pump the bulb, engaged the chock, lifted up the idler, and it wouldn't start. I attempted for about 15 min and decided to let it sit awhile. tried again after about an hour and still no luck. after about 10-15 more min it finally started and ran fine. I was afraid to shut the boat off again so i just went home. the next morning i hooked up the water hose to it and it fired right up......... did i flood it and is there a trick to starting an outboard if it's flooded?
