lastchance32
- Feb 18, 2010
- 23
Working on this boat for a friend. Bought boat and engine separately and just finished rigging it. First time out on the water I had a fuel restriction alarm, but seemed to be running properly. I shut it down and checked all the fuel lines, valves, filters, and bulb. Found the problem, had blockage in the line between the fitting on the cowl and filter. Took boat back out and it ran great, 5500 rpm wot @ 57 MPH. Shut down boat to do some fishing, when I restarted, it would not get on plane. Seemed to be running very weak. Took it back home went through the carbs, and did not help. Everything seems good at idle, not missing or rough, but when you throttle up in gear, it is not revving up like it did before. Any thoughts or suggestions?
