While removing the starter to get at the carb tonight, I broke the head of a bolt off that holds the starter to the rear of the motor. It is one of the two bolts that pin down the the rear lower starter bracket/swivel point. It is below the top of the bottom half of the engine cowling. Well below the belly pan so I cannot get a drill bit/screw extractor at it.
How do I remove that part of the cowling? Thanks!
JJ
JJ
