I just finished replacing coil, points, condensor,plugs etc. I tried putting the flywheel on and could not get it to sit against the timing cam at the bottom of the shaft for the life of me!! I had to battle to get the flywheel off and I though that maybe I damaged it so I bought a used one in great shape thinking I just messed the original one up. Got it in the mail today, go to throw it on and NO GO. It will Not seat against that cam either. I have cleaned the hell outta the shaft and flywheel tapers. I have the nut tightened and can lift the flywheel up and down enough to hear it clunk a lil. The whole crankshaft is moving with it. Any ideas as to what's goin on here? Is it supposed to move a little? I'm new to all this so any help would be appreciated. Thanks all
