Roadking5901
- Jul 29, 2013
- 3
Hi, Purchased a boat with a johnson v90. Motor had an overheat on the starboard side at somepoint. Replaced the water jackets,(both sides) after breaking off most of the bolts in the mean time. Replaced the gaskets and temps sensors, scraped out the water jacket channels as best I could(motor was used in salt water). Replaced the impeller, Left the thermostats out!. Ran the engine,(in a barrel) great flow from the pisser tube. After several mins, checked the water jacket temps with an infared gun... Temps on the port side 135-155, on the starboard 190 as the warning horn was going off. Attaching a pump and hose to either water jacket(bottom), great flow thru the other side and out thru the prop, and above the anticav plate. Water from the pisser tube gets very hot when the engine is running. Any ideas? Thanks.
