Hi,
I'm in the process of removing the starter assembly so I can get to the carb and clean it. I noticed a wire that's connected to the starter bracket near the solenoid and another end down by the fuel line connector. It's looks like it was cut because the 2 ends have a perfect angled cut. I'm no master mechanic, but it seems these 2 wires should be one. What is this for? Is it a ground for the fuel line connector? I tried finding it on the exploded parts lists, but haven't had any luck.
You can see in the picture what I'm talking about.
Thanks
Thanks
