I've been working on this motor for several months trying to get it to run.
Here is what I know. It used to run pretty good. Rough and not very dependable but it would get the boat up and plane at WOT.
This is what its doing today. It starts really hard, and very cold blooded. Needs lots of choke and seems to lack either the power or rpms or both to get the boat to plane. Yesterday I had it out testing it and went through some weeds. It caused the prop to cavitate and I'm pretty sure the motor went to WOT. I let it run like that for just a couple of seconds to make sure it would stay that way and it did. As soon as I let off the throttle and ran it back up...... same thing. Just acts like it doesn't have enough power to run back up to a high rpm.
I have checked the cylinder pressures and they are all between 105 and 115.
Checked the spark plugs with a gap tester and could jump a good 1/2 inch but not sure about how hot it was.
Checked each spark plug wire with an induction timing light and had spark on all 4
Rebuilt the carbs and replaced all of the jets, gaskets and cleaned them.
I've also replaced the spark plugs and one coil. Its got fresh gas some sea foam and some octane booster in the gas.
Pumping the primer bulb at WOT has little or no effect nor does hitting the choke pump.
I'm going back out today to pull all of the plugs and see what they look like and to double check the cylinder pressures. I'll post back with the latest.
My grandson and I really like this boat so I'm hoping I can get this motor running before the lake freezes.
