So this may be a stupid question but I am stuck. I have had other outboards and to remove the top cover you simply flip down the latches and lift it off. I bought tis boat in November of 2012. The owner winterized it and fogged the cylinders, etc. I assume that would require the cover to be removed. I have had the boat out many times this year and haven't had the need to remove it until I had a fuel issue. I flipped down the lock on the front and the two locks on the back and pulled and it doesn't move. I wiggled, shook, tried to lightly pry in the seam and nothing. It doesn't budge.
What the heck is going on??? Any help would be appreciated.
