chrislee73
- Jul 28, 2013
- 7
I bought a boat yesterday, and it has a 1978 Johnson 115hp v4 2stroke engine. The Model # is 115ETL78c. (Can't find parts anywhere!) I started it up before I took it out, and it's leaking a good amount of fuel from around the brass fitting I the bottom of the fuel bowl. Thought it was the line, replaced it with no luck. It's pressed in, not threaded. I put it in a press and removed the fitting, is there supossed to be an o-ring on it?? Any help?
