barnstormerj
- Jun 13, 2011
- 33
My 140 johnson will not choke , hard start. I can not get the choke to work when holding in on the key as it should. I can choke it by raising the little red lever under the cowl .Can anyone help me find the wiring diagram to the choke from the control handle, color of wire to the harness, any help with a wiring diagram? I would like to know which wire to search out , or where to look on the engine for the solonoid that opens the choke . Should start easy, but choke does not work. Jack
