I have a 1956 15 hp johnson that I recently bought on Craigslist. It sat for many years.
It is running well now after replacing coils but has a pretty bad fuel oil leak where the powerhead meets the lower unit. It is on the front of the motor the shifter side. When going full throttle not much of a leak but when going slow it sprays out. I guess this is actually the bottom of the crankcase. Could the lower crankshaft seal be causing this problem? I plan on replacing the seal but while apart I'd like to be sure and find the leak.
I've been checking for the gasket where the powerhead meets the lower unit and can't find it anywhere what is the best replacement. Should I make my own?
I hope it isn't in the crankcase I'd rather avoid taking it apart. Any ideas, Thanks
