I have a 1958 35hp evinrude. The problem is that only one plug will produce spark. I've replaced the points, the condensers, the ignition coil, plug wires and still no spark out of the top plug. What should I check? What troubleshooting techniques can I do to try and get this figured out? Thank you in advance
