1958 johnson 18hp wont plane
henry954
ok guys, got it on the water today . got a 14 ft alumacraft jon boat. Motor is dialed in . she revs hard idles perfect but when I go full throttle I don't go any faster than 5 mph. Im posting some pics. its either the prop (there are no sharp edges) or the gears ?IMG_1141 (640x480).jpgIMG_1146 (640x480).jpgIMG_1148 (640x480).jpg again motor is revving the problem isn't there . you can feel she has power. but she wont plane and is very slow. could the prop be the problem being so rounded off?
jonbellamy
Re: 1958 johnson 18hp wont plane
Is it revving up when you punch it full throttle? Or is it not getting high rpms?
henry954
it is revving up. the motor has more than enough power to pull this boat. it just is not hooking up. going to check this prop hub
henry954
can someone recommend a good prop for this motor, And a place to source it from. Nothing fancy. I don't have a press to remove this hub . might as well change it .this prop is toast anyway.what pitch
64osby
If it's not a spun prop, check to see you're getting spark on both cylinders. It will run on one and be a dog.
henry954
not yet. but I put the prop on a vise and the hub seems to have some slop in it.
nwcove
if you didnt confirm it to be spun, dont go out and buy a prop. as osby said, those motors will start and run quite well on one cyl, but just wont get up and go.
henry954
ok guys made two punch marks.one on the hub ,one on the prop. tested and no movement whatsoever.so that's not the problem. I cant believe its running on one cyclinder. both plugs are new and they look identical after running for some time. im getting spark on both plugs.
phillnjack2
Ensign
what size is the pitch of the prop and diameter ?
maybe the prop was for a heavy boat with a small pitch etc,if so youl never get high speed.
also is the shaft length correct ? i.e shortshaft engine on a longshaft boat ?
just a couple of thoughts.
phill
henry954
furthermore just went downstairs, started it and took turns pulling spark plug wire while running and when u pull one it runs on the opposite no problem, but they r both firing fine. what about the lower unit. can something go wrong in there. what height does the prop have to be in relation to the bottom of the hull. is this an issue
henry954
phil, ok boat is an alumacraft jon boat. 59 inches at its widest in the back 14 feet long and twenty inches high at its highest point. im going to say prop is 8 inch diameter pitch I don't know its not on the prop.
henry954
oh the shaft on the motor is 32 inches from bottom of skeg to bottom cover of motor long shaft right?
nwcove
are you testing for a spun hub in a barrel or on the water?
( as far as long shaft/short shaft goes......measure from the transom clamp to the anti vent plate above the prop.....from where you measured 32" it would make it a short shaft tho)
henry954
im testing in a river nearby. IMG_1150 (640x480).jpg this pic shows the prop shaft is pretty much level with bottom of hull. is that bad.
nwcove
wow!!! what is the measurement on the transom height ???? sure looks like to much stern ,even if you trim the motor in to its last notch! cant imagine the prop being able to get good water with the motor that high.
nwcove
you either need to find the parts to convert to long shaft ( not so easy) or do some careful measurements and cut the transom down and seal it up. or buy another boat that is made for a short shaft motor. jmo
