billbrach
- Aug 5, 2009
- 9
When the motor is cold, PSI as measured at the schrader valve is mid 20's. With the engine idling, pressure slowly falls off, over 10 minutes or so, to 5 PSI, at which point the motor usually coughs and dies.
Does this sound like a bad injection pump ?? Pressure at the lift pump, as measured at a temporarily installed "tee" on output side, stays in the 4-6 PSI range the entire time.
I have the OEM service manual and diagnostic software and cable, and the only unusual event was an EMM overheat, that occurred once, at about 265 hours. Engine now over 267 hours.
Any ideas ?? Anything else to check ??
